- Mar 13, 2005
- Raleigh, NC
It would start to stall in 4hi if I was starting to climb a rock on flat ground. Always in 1st gear
That doesn't sound unusual. Does it climb the rock in low range?
It always cranks just fine. I will check the fuel pressure again.
I watched it do it a few times at Harlan.
It seemed to me it was stalling by having too low of an idle speed
I say TP and/or IAC buddy
Too low of an idle speed is a symptom, not a cause.
Which can be caused by tps && || iac
IAC only matters at idle. A bad/clogged IAC doesn't have any effect under any other condition, including any throttle opening or any engine load. TPS, yes. MAP or MAF, yes. IAT, maybe.
Idle speed doesn't matter. He said it was to the wood and stalled anyway.
The only way I made it around Harlan on the steep hills was in 4lo and 1st gear and beating on the rev limiter (I even caught some air as @77GreenMachine saw)
So where do you guys get your items like a TPS? I have to say I just replaced the TPC a couple years ago when I was having distributer problems, but I did get it from o'reilly or advance if I remember correctly. Is rock auto the place to go?
Electronicols I like going with OEM. Amazon Link Here
Or, ya know, you could put a meter on the TPS and see if it's defective before randomly throwing parts at it.
Don't remember saying I'd blindly throw parts at the problem, I was just merely providing where I would get one from.
On a side note Clay I have a meter if you don't, a scanner would be the easiest way to test it though.
It doesn't throw any codes, even during and after the stall, so would a scanner still do me any good?
