Redrilling hubs - anyone?
Blaze
The Jeeper Reaper
Wake Forest, NC
I have a set of front hubs off of a 61 Ford F100 that I need redrilled for a 5x4.5 bolt pattern for my 56 Chieftain gasser. I want it done by a real machine shop that can get it right so I'm not getting wicked wobble running hard down the drag strip. Currently it is 5x5 I think.
Can anyone do this? I have been trying to find brake rotors with hubs that fit and I failed.
@4wheelsupply maybe? Really any good machine shop should be able to do it. Guessing adapters are a no go?
I'm trying not to use adapters if I can help it. I may if I can't get them redrilled but being a vintage gasser I'm trying to not use things like that.
Hill top machine. Then we can get a video of him doing the work. @tknopp
I had a set of 9" axles predrilled by carlton customs in Greenville sc
Tis true, but I basically made a wheel spacer and put a drill bushing in it so I can do it again whenever I replace the unit bearings. His is just a one time kinda thing.
I started to do the same thing but all the guys flipped out about it, I guess when you are pulling the wheels at every shift and trapping 100+ in the eighth in a 50s straight axle car you want the front tires to be dead nuts on. LOL
Mine are (dead) nuts. I made the center of the spacer locate off of the center hub bore where the rim seats so everything is concentric and it rides smooth. It just makes it much easier to repeat without having to throw it in a CNC mill and probe center. I even used the 8x170 spacing to located it so the 8x6.5 pattern is clocked center between the original holes. Worked out nice.
