mommucked
Endeavoring to persevere
- Sep 26, 2011
- Rural Apex n.c.
Proforged?Moog?ACDelco and why?
Historically, I've always tried to buy moog. Had some hit and miss experiences in the last few years and tried mevotech on somebody's recommendation. Appearance/fit/finish of the parts is at least as good as moog, and I haven't had to replace any of them yet.
#1 OEM (original equipment, not the ghey Chinese "OEM" brand from eBay or whatever)
#2 Dana/Spicer
#3 Moog
#4 Everything else
There are also specialty brands within a niche that are usually good. A bunch of the GM and Ford guys have had issues with Moog quality.
I bought some moog RK "problem solver" upper A arms w ball joints for my 98 K1500 4wd from rock auto and they don't have PS stamped on them.Now I think RK is the low grade and the CK is the the good shit.
I'm pretty sure they just put "Problem Solver" on everything they sell these days for brand recognition and its-wut-my-diddy-used credit.With ball joints, aren't the "problem solver" ones usually the knurled ones that are oversized to fit stretched knuckles/yokes? I'm not sure how they apply that terminology to a case where you're buying the whole arm. Can you buy the ball joint separately, but the "problem solver" comes with the whole arm/bushings/etc? If so, the ball joint wouldn't need to be oversized.
AC Delco Professional and Mevotech are two of my favorites, along with some of the Moog stuff. Hit or miss on Moog for some reason now a days.
I had some Moog parts wear out insanely quick on the SD axle under my HD. Chunked those for Mevotech stuff and I'm still running them.
What ones do yall have? these..
More Information for MEVOTECH TXES2836RL
or these?
More Information for MEVOTECH MES2836RL
You know your steering is sketchy when a couple zip ties make a noticeable difference!So I found out the tie rods are good, the pitman arm has some slop in the joint and the shaft seal is leaking.Gona fix it sat.Pull the box and put new seals in it and put this HD pitman on.View attachment 332077 until then, I put a bandaide on it.
took it for a drive and the zip ties made a difference.
