kaiser715
Doing hard time
- Jun 1, 2006
- 7, Pocket, NC
I got a 16' farm gate on my driveway. Put it up when we first bought the place. Used an 6x6 post about 3.5' in the ground. Had to adjust/straighten the post a couple of times as the weight of the gate pulled it out of kilter.
I got some drops of 8" steel square tube, about 6' each. What I am thinking to do is to pour a concrete footing, with anchor bolts to bolt down the post (I'll weld it square to a piece of 1/4 plate). Shims or bottom-side nuts to level.
The gate weights 151 pounds. Two questions about the concrete base: 1) how much weight should I plan for in concrete; and 2) square and deep (3') or larger surface area and 1' or less deep?
It will need to support the gate in 2 positions, open and closed (90* to each other)
