Perfect. Thank you.It’s pretty typical to off set the track bar to clear the diff. It just need to be parallel with the drag link.
you should have ZERO issues with those angles. looks goodPretty close, but still needs a minor tweak (and maybe a bend). Now onto finding a spot for the upper link. View attachment 341342
Except the track-bar hitting the diff and the oil-pan.... hopefully a paychecks worth of bumpstops will help.you should have ZERO issues with those angles. looks good
How far are you from full bump in that pic?Except the track-bar hitting the diff and the oil-pan.... hopefully a paychecks worth of bumpstops will help.
That pic is my projected ride height, there will probably not be more than 4” up travel. The axle has pushed forward a bit more since that first pic.How far are you from full bump in that pic?
Looks like plenty of room on the driver's side, could you do a low profile truss and move it over?Now that we have that settled, what size tube do the guru’s recommend for the upper link? I bought a tube/heim kit from @Barnes 4wd that came with 2x.250 for both the lowers and the upper. As you can see there’s not a lot of room for the upper link. Can I get away with 1.5”x something for the upper link?View attachment 342107
I’m trying to stay fairly low. At full bump I can barely squeeze my hand between the diff and the oil pan.Looks like plenty of room on the driver's side, could you do a low profile truss and move it over?
That was on a Thursday evening in Harlan. Wiped out the front coilovers, his weekend was done for.
My vote would be tapping for 1.25 heim, but I'd say either option would be pretty close as far as strength. Track bar looks pretty similar to what I had to do on my Tacoma.So it seems that 1.5 x .250 wall it is. But now the question is do I tap it for 1-1/4 heims (I’ve already got the heims, but will have to buy both RH and LH taps and pay someone to put it on a lathe? Or do I use a smaller heim and weld in tube adapter (probably a little cheaper in the end)? View attachment 342330
that track bar is ugly, but just barely clears both the diff and the oil pan. I’m still not satisfied that it is the best solution. View attachment 342331
Some guys with lathes already have 1-1/4" RH and LH tapsSo it seems that 1.5 x .250 wall it is. But now the question is do I tap it for 1-1/4 heims (I’ve already got the heims, but will have to buy both RH and LH taps and pay someone to put it on a lathe? Or do I use a 3/4 heim and weld in tube adapter (much cheaper in the end)? View attachment 342330
Do you know of anyone convenient to I77 between north Charlotte and Elkin?Some guys with lathes already have 1-1/4" RH and LH taps![]()
I'm 25-30min from 77/485Do you know of anyone convenient to I77 between north Charlotte and Elkin?
