marty79
the LS Swap Guy
- Nov 24, 2013
- Conover, NC
Anyone here have experience using the Quick 4 from US Shiftware?
Working on customers 1990 G20 5.7TBI. Had 4wd conversion done many years ago with a 4L80E installed and it's never shifted right according to him, mostly ALWAYS has shifted right out of first gear immediately no matter what throttle, no matter what you set shift points to. So long story short that was done at some shop out of state, doesn't help me and I'm trying to learn the software but after learning my way around this Quick 4 controller and settings, I've overlooked all the wiring and everything seems to mostly check out.
No matter what "shift tune" I upload into the controller, trans still shifts out of 1st gear like instantly...
Also if I manually start in 1st gear still barely gets any rpms then immediately shifts to 2nd as well.
All other gears seem to shift pretty good, little "laggish" going into OD but 2-3, 3-4 shift pretty smooth/as normal as I would expect for the most part.
Thank you for any guidance. I'm new to "programming" transmissions lol but according to US Shiftware, it's a pretty simple setup and of course the tech guy on the phone couldn't tell me much more than I've already figured out that it's Not doing.
