marty79
- Dec 2, 2015
- Newton, NC
ok so I pulled a stupid today...working on a carbed 300 ford six, was in for hesitation/slight miss..I pulled plugs, checked compression, etc.
When I put it all back together, I Stupidly unknowingly left my ratchet still attached to the crank and when I started it, it ran kinda horrible then died...cannot get it to fire for nothing!! (and yes it snapped the head right off my Snap On Ratchet lol).
SO...Please Help with ideas: These fords are known to strip the cam gear since it's plastic junk...BUT distributor still spins fine when turning over and every other motor I've looked up that breaks/strips cam gear, distributor doesn't spin (obviously lol).
It got an HEI big cap distributor on it from years ago, but it was a cheapo not the good quality one.
I know I did a booboo but now I need help getting this truck working lol and I don't mind buying new distributor or timing but was trying to see if yall think I still need to pull front end apart to verify timing of crank and cam?
**I have set the motor to TDC and set distributor pointing at #1 on cap like 5 times to be sure. I even tried putting firing order one before and one after...no change in how it sounds...doesn't hit a lick.
Main Question?. Is it possible the cam/crank jumped time even though it seems impossible cause every other thread I've read it looks like the cam gear teeth would strip right off before "jumping" time since they're plastic and crank teeth are steel??!!
