awheelterd
- Oct 18, 2007
- Kenly, NC
Buncha rich folks going to Lowes. I've been hitting up builders discount the past few weeks while building my kids playset. It's a little twisty....
BDC closes to damn early, by the time I’ve got my shit together enough on a Saturday it’s 12-1pm, BDC closes at 1.Buncha rich folks going to Lowes. I've been hitting up builders discount the past few weeks while building my kids playset. It's a little twisty....
I will say, I don't know what happened, but the $2.87 2x4x8 studs from my local Home Depot are surprisingly straight. I'm used to having to hunt through the stacks to find decent ones - these have all been spot on, only a few have a slow bow.
Neighbor had an interesting theory.I noticed that too at Lowes, bought some 2x4s and all were fantastic. It was really weird.
My theory is that they used to buy the cheapest shit possible. Then everything became expensive so they started buying decent shit again. Give it a month or two and it'll be back to normal.Neighbor had an interesting theory.
Normally they have a huge stock with a buffer, where it sits for some period of time before ending up at the local yard, and then sits a bit before you are pulling off the shelf.
At the moment the biffer is gone, people are nabbing it as fast as they can get it in.
No time for it to sit around and get warped, bowed from sagging on the pallet, etc.
My thoughts are kind of the opposite. I would think being strapped together in a nice bundle while the wood dried would help keep it from warping up so bad.Neighbor had an interesting theory.
This is regular non-PT kiln dried.My thoughts are kind of the opposite. I would think being strapped together in a nice bundle while the wood dried would help keep it from warping up so bad.
Sounds more like a real hardware store, lol.Our Lowes hasn’t had a “run” like y’all are talking about. They have plenty and folks weren’t panic buying.
This Lowes is a little different with a drive up lumber area in back where only pretty wood is inside and most is outside under big shelter. You drive around to get most framing , PT and sheet lumber.
I used that stuff for my shed floor too. It sat out in the weather for probably a year before I got the shed 'dried in'. It got rained on MANY times, and even got snowed on at least once. They must put some great stuff in it because it still looked good and hadn't swollen up.Finally making some headway on my shed.
Pulled all the advantech OSB out of my basement floor, decided it was better used as shed decking. Boy thst was a PITA but it saved a bundle.
Aside- I am totally sold on Advantech OSB. it is heavy and expensive but the water repulsion and stability are incredible.
I've had a very small amount of swelling at the edges where the boards meet and on the ends, just enough that it isn't perfectly flat. But nothing like normal OSB.I used that stuff for my shed floor too. It sat out in the weather for probably a year before I got the shed 'dried in'. It got rained on MANY times, and even got snowed on at least once. They must put some great stuff in it because it still looked good and hadn't swollen up.
When I finally got my shed finished, I painted the floor a tan color just for appearance. I'm glad I took the time to do it.
Big skidsteer?I may be a bit too ambitious. Not sure how a guy can get these monsters on the mill. The one closest to the mill is maybe 1/3 the size of the other 2.
My local HS football team sucks enough at football already. No need getting them hurt.Local football team?
Stop being a little bitch and pick it up.
Kinda where we are going.Couple of pipes/logs/beams to use for ramps and a come along?
