Operation shop rehab
Loganwayne
#BTL
Clyde, North Carolina
The house we moved into was my fiancés grandparents, it also came with a LARGE shop. The kicker is it’s packed full of stuff and the property as a whole is in major disrepair. First steps is to clean the two drainage ditches on either side of the property, both are silted in and causing the back yard/ front of shop area to be extremely wet and boggy. Second step is to remove all of most of the trees. Then to remove the old vehicles and clean up enough that I can at least mow all the way around the shop again.
There’s a fox body mustang, iroc Camaro, a 70s f-100? Or 150 a early 90s f150, full size jeep cherokee. Plus a ranger roller, s10 roller some kind of old van, a ford sport trac.
Oh and can’t forget the rv in the back of the shop and the camper In front of it
Why are you cutting down the trees? Maybe the pictures will explain.
The field in front of the shop I bush hogged last year. It was just an area with briers above my head
More
Outside doesn't look too bad. How much stuff is inside?
First 8 hours in and got most of the trees cut. And have pissed one neighbor off.
Also realize I’m going to have to put a ditch across the whole lot but don’t think I have enough fall going to get a transit tomorrow to see.
Oh and only popped the track off once
What was the neighbor's problem, he doesn't have the screening that he used too?
I didn’t cut every singe tree on the fence line. I left the trees that are healthy and alive and the ones that are dead on his side of the fence that he still expected me to cut. Which I would have but he’s kinda a jerk and a noisy neighbor, I can’t walk out my door into the back yard without them coming out to see what I’m doing
Start going outside naked, they will move.
