Gojira94
- Apr 29, 2022
- Clayton, NC
First, bear with me as my MJ project is my first 4WD anything. Plenty of GM platform 2WD builds, swaps, mods over the last 25 years, mainly 4th gen F-bodies and crazy OBS SBC builds/ LS swaps. First time dealing with transfer cases. Novak Conversions gave me a ton of background info on most aspects of what's what.
Here's what I'm doing: take a basket case 87 MJ 2WD/ 4cyl and convert to 4.0 HO/ 4WD, run it off a Renix 429 ECM. TPS adapter accounted for, none of the engine swap is an issue whatsoever. I don't plan on a lift now, but maybe at some point a 2" lift might be something I'd do to accommodate a larger tire than the present 235/75 R15. I have a re-clock jig on the way for the rear half of the trans case to fit everything into an MJ/XJ tunnel.
Donor vehicle for the engine, AX-15, NP231 is a 93 YJ. I also have a 231J from a 98 XJ I bought from a member here a few months ago. The output shafts are different/ rear housings different length. The thought is the shorter the housing/ shaft, the better for driveline angle at the rear pinion. No matter what, I'll have to shorten the driveshaft I have. The further apart the case output and rear pinion yoke are, the better, right?
The XJ case I got off the forum is locked up tight, no idea how bad it is inside. Was supposed to be a 'working pull from a lightly driven 98 XJ.' Paid $125 for it and put it away since it was for much later in the project. more or less complete driveline from the 93 YJ came in July. I was going to use all of it but then I noticed the output end differences and thought it might make more sense to use the shorter output case I bought before. That's when I noticed the one from the XJ is locked up. So... Reading about going to a SYE, "moving the slip yoke to the driveshaft" I don't know what that means or looks like at the driveshaft. Do I even need a SYE? I'm clear on how to install one, just no sure what needs to be done to the driveshaft to accommodate a SYE. The rear needs to move up/ down (Y axis) but without some sort of slip yoke somewhere it would be bound to a fixed arc of travel, which is a no-go, of course.
My gut says either use the YJ case as-is, since it's definitely shorter overall or put a SYE in it and find out what needs to be done to the driveshaft to run it. And use the 98 XJ case for a rebuild/ spare.
Pics:
93 YJ case:
98 XJ case:
Pics:
93 YJ case:
98 XJ case:
