So a few weeks back I was doing some work on the truck, noticed I was leaking antifreeze so I was going to add some to the system while I searched for this leak. That’s when I noticed some sludge in my coolant reservoir. I use the truck to pull a trailer 4 days a week for work so I’m my mind, taking it to a shop and letting them flush the system, find the leak and check to be sure nothing else was going on was a better/quicker option for me.
Three weeks later, about 12 flushes, new t-stat, water pump, coolant reservoir, oil cooler, and A leak fixed, pick the truck up on a Saturday only for it to be leaking at water pump.
Take truck back to shop, they now say there’s fuel in the coolant and that’s what caused the gasket to fail on water pump.
I’m not an expert but it seems a little quick if any fuel were present in the fresh coolant, for it to cause the water pump to leak as if no gasket were present to begin with??
IF there is fuel in coolant, would that be as a result of a leaking injector?
It's all about perspective!
