Right now I'm heating my garage w/ a couple small resistance heat units but been thinking about getting a propane unit or just biting the bullet and putting in a mini split (which I know to be the correct answer).
After doing some math I thought of this thread and thought I'd pass it along given
@skyhighZJ 's point about wanting to ditch electric but the potential issues with propane.
Heres's some math to consider:
After taxes etc we pay $0.237 / kwh for electricity. (this is also a reminder to me its time to re-look at distibutor & plan options).
A typical 1500w resistance heat unit provides 5100 BTU. That means 2 of them running together to get 10.2k BTU for 1 hour costs me $0.71.
Meanwhile the 9k BTU mini split I put in the sunroom is reliably pulling a little under 400ww when running full bore (measured via current monitor). If I were to move up to say a 12k unit for the garage and it uses 33% more juice that would cost me $0.126 per hour (full bore). 5.5x cheaper!
Around here a typical 20 lb propane tank (that is actually 15 lbs) costs $23, or $1.53 per pound.
A pound of propane is 21548 BTUs.
That means if you set the regulator to say half, at 10k BTU, to get in the same range as above, it would use $0.711 worth of propane in an hour.
Soooo.... cost per BTU, propane is saving nothing over good old electric resistance heat. Plus it comes with the moisture problem (over a pound of water per pound of prpane used) added to the atmosphere. AND you have to keep switching the damn thing. The only thing it buys you is convenience of doing it anywhere or getting a crap ton of BTUs all at once. Or maybe you're buying prpane in a larger quantity at a better per-lb price.
I'll also be the first to say this is ideal math and I'm probably missing something. But in the meantime I'm now finding myself guestimating math on how many hours a year it would run to make up the difference in cost. at a difference of $0.58 per hour for 2 ceramic heaters vs mini split, even 100 hours run time a year at full bore is only 58 bucks. But it also provides A/C. I have a 12k window A/C unit now so thats covered but I'd wager its 1/3rd the efficiency too....
