mbalbritton
- Mar 22, 2005
- Greensboro, NC
IIDK,CYTMNever know what youre gonna see at the recycling place.IYKYK.
Same here. Based on the integrated bell housing, I’d guess Ford ZF6 or something? Bolted to a 351 or 460?IIDK,CYTM
It’s a diesel motor tho… valve cover sticker says intertrashanalSame here. Based on the integrated bell housing, I’d guess Ford ZF6 or something? Bolted to a 351 or 460?
It's a 6.9 or 7.3 idiSame here. Based on the integrated bell housing, I’d guess Ford ZF6 or something? Bolted to a 351 or 460?
Well that’s disappointingIt's a 6.9 or 7.3 idi
Shit, I just had to pay 300$ for a clutch fork for oneThat is a diesel zf5 speed 4x4 trans very desirable trans would bring 750 to 1000 dollars not counting the flywheel another 100 bucks if it is a1 piece flywheel.
Yeah I got both of em.1140 pounds cost me $171I'm really hoping you brought that home with you?
If you're use to the power of a modern diesel engine it absolutely is.BUT there's a market for 7.3 IDI stuff,suprisingly enuf.Well that’s disappointing![]()
7.3It's a 6.9 or 7.3 idi
They'll part for more than that now.It still had the old style flywheel in it.Scrap is $7/ hundred so they got about $80 for it.If i was close to where that is i would buy it in a hot minute.
Are they bringing that much now??Shit, I just had to pay 300$ for a clutch fork for one
Yes I can.IIDK,CYTM
I’m sure gearing makes a difference too. Dads old 6.9IDI F350 dump truck was paired with a T19 with a 4:1 first gear and 3.x axle gears in a 4 ton truck with no power.If you're use to the power of a modern diesel engine it absolutely is.BUT there's a market for 7.3 IDI stuff,suprisingly enuf.
When yours falls out due to a worn pivot and you can’t find one anywhere lolAre they bringing that much now??
Lack of a turbo doesn’t help either.I’m sure gearing makes a difference too. Dads old 6.9IDI F350 dump truck was paired with a T19 with a 4:1 first gear and 3.x axle gears in a 4 ton truck with no power.
Eh take the inspection plate off, tuen that little Allen screw and throw the fuelI’m sure gearing makes a difference too. Dads old 6.9IDI F350 dump truck was paired with a T19 with a 4:1 first gear and 3.x axle gears in a 4 ton truck with no power.
I turned it into a 2017 Ram 5500 deleted and tuned with 4.88 gears and a frame and suspension that could actually handle the weightEh take the inspection plate off, tuen that little Allen screw and throw the fuel
Wow, I bet that cost them hundreds of dollars!Some of yall might not be getting your orders for a while.
