Tahoe has dual climate control, I’ve replaced the control unit used to adjust heat setting, actuator on passenger side under dash replaced last year, and I’m currently fighting the one under dash on driver side which controls where the air flows, through vents, floor, defrost.
The issue now is, the heat will only work when the temp is turned up all the way to 90. If you set it to 89, it alternates between warm/cool air. I’ve tried searching around and came across a fix with inside air temp sensor located above driver head in headliner, changed that and still not fixed.
Heat/AC works on both passenger and driver side, rear works too. Just the heat only blows consistently hot at 90, any other degree setting and it’ll get cool/cold for a few minutes then warm up, then repeat
Any suggestions?
Any suggestions?
