ScottR
It's never done.
- Mar 21, 2005
- Raleigh, NC
I washed my jeep this weekend. I sprayed some water on the lower sides of the engine, in between the frame and inner fender. So things like the starter, distributor, coil did get wet. Then afterwards, it wouldn't start. It will turn over, but will not fire. I confirmed that there is no spark with an inline spark plug wire test light. I feel like there is fuel- fuel pump cycles and I can now smell fuel in the engine area- cylinders probably have plenty of gas since I have tried to start several times...
I replaced the camshaft position sensor (wafer thing in the bottom of the distributor) last night. And I swapped the ASD relay with the Horn relay in the fuse box. Still no change.
I tested the crank position sensor by turning the key to the 'On' position and then turning over the engine by hand- the fuel pump would cycle as I turned the engine. This was a test I saw on BleepinJeep youtube. Is that test sufficient or could the issue still be the CPS? I had a no start issue last January and that was resolved by replacing the CPS.
I have checked several other threads- answers vary; Crank Position Sensor (replace and just unplug for 5 minutes- tried the unplug thing), Map Sensor, Throttle Position Sensor, Ignition Coil...
What should I replace/test next?
I am trying to get this figured out fairly quickly. Our family is going to the CNC 4x4 Fall Bash next weekend and we are out of town this weekend...
