Currie Bears 44 Complete Axle with WJ Steering XJ TJ ZJ
kcox506
Hayesville, North Carolina
I am parting out my Cherokee I raced/wheeled for a number of years. This post is for the front axle. It's all been sitting outside for a couple years so it's a little cosmetically worn. Lots of goodies packed into this axle. Here are the specs:
- 4.10 JK Low Pinion Gears
- ARB Air Locker
- Rare Parts Ball Joints
- WJ 1 Ton 7075 Steering Links with WJ Knuckles. Set up for OTA.
- Custom OTA Adjustable Track Bar sleeved internally with 7075 Aluminum
- RCV Axle Shafts
- TNT Customs Truss with 1.5" Stretch
- Ironman4x4fab C Gussets and Lower Control Arm Brackets
- Hydro Assist Skid with 6" PSC Ram
- Sway Bar Links set up for Currie Antirock Setup
- 3/8" wall Axle Tubes
- Ironman4x4fab Lower Coil Retainer Kit
From what I know, this was the strongest axle you could get that was still a Narrow D44 that bolts under a TJ XJ ZJ etc. I believe they have a HP version of this now. Overall this axle doesn't have much time in the field. Put it in mid race season and then that was it after that. Just a few wheeling trips. Willing to throw in the coils and limiting straps. Ask for anything else, willing to part with most things that were on it. Hydro lines not included, as I need them for a new project.
I am asking $2500 for the whole lot. I am in western NC near Murphy. Willing to meet anywhere within reason.
In case anyone else was like me and had no idea what this was…for a few years the Currie built axles had a center section was cast by a company called Bears and they are beefy.
The Currie designs have 18 more pounds of iron than the stock 44, wonder if the bears is more or less. There are also some bosses that the Currie 44 doesn’t have by the pinion
