6k Rotary Belly Lift
paradisePWoffrd
Recovering Project Junkie
Newton, NC
I dont use this lift as much as I thought, so looking to get it out of my way. I don't know much about it, I bought it used and have only used it a handful of times.
Great for someone to use for detailing or paint/body work, brake/suspension work.
6000lb Rotary Belly lift.
~24" lift height
110v.
Cylinder may need resealed. Nothing leaks, but it doesn't retract unless there is weight on the lift.
$750obo.
Located in Newton, NC. I have a tractor to load on your trailer.
Here are the pictures.
Dang. Thanks ofr the tip. Unfortunately its a trek and getting this home in my Mazda would be... interesting.
But just for S&Gs.... @paradisePWoffrd how much does it weigh?
Goes back to what I told you. Rent a uhaul and their trailer to bring your Toyota to the G2G. Sleep in the truck. Now: bring home belly lift in said U-Haul truck toting your (now broken from wheeling) Toyota back home. But you have a lift to work on said Toyota……
I swear! It’s like no one listens around here!
I dont have a clue, but its alot of heavy plate. Might could pick it up with 4-6 ppl. Could likely take it apart, but the base and H frame are single pieces, so definitely not fitting in a car.
