ncpartsguy
- Sep 25, 2010
- Boone, NC
Aurora from Boone
What's the story with this one?
Are you studding or doing anything to this one before install? I'm not sure if @Clubbs is asking the same question.
No, just leaving it stock and unopened. I need to get the truck back on the road.Are you studding or doing anything to this one before install? I'm not sure if @Clubbs is asking the same question.
Swapping it in my blowed up truck. Long story short, once I got the pistons out, I discovered the #1 cylinder was scored, so I took my engine serial number to the Cummins website and looked up the stock bore liner. $140 or something and in stock, cool. No liner puller, so I did the old run-a-few-beads-of-weld on the cylinder wall so the liner would shrink and pull out. A couple beads wasn't enough, so I ran a couple more and a good heavy bead around the top to relieve the press fit. Still nothing. Do some digging online and discover the 6.7 Cummins doesn't have liners, and the liners Cummins sells require you to pre-bore significantly oversize, so I'm just sitting there welding to my block like a tard.What's the story with this one?
Tired of this stupid project that I didn't even want, need to just move on.Pretty sure Matt was referring to the driver getting out of the car, or atleast that is where my mind went.It has a hitch, just haul it all to the scrap yard in one run!
Damn it son I hate that for you, but i absolutely appreciate you sharing. Im laughing my ass off like a good friend should.No, just leaving it stock and unopened. I need to get the truck back on the road.
Swapping it in my blowed up truck. Long story short, once I got the pistons out, I discovered the #1 cylinder was scored, so I took my engine serial number to the Cummins website and looked up the stock bore liner. $140 or something and in stock, cool. No liner puller, so I did the old run-a-few-beads-of-weld on the cylinder wall so the liner would shrink and pull out. A couple beads wasn't enough, so I ran a couple more and a good heavy bead around the top to relieve the press fit. Still nothing. Do some digging online and discover the 6.7 Cummins doesn't have liners, and the liners Cummins sells require you to pre-bore significantly oversize, so I'm just sitting there welding to my block like a tard.Tired of this stupid project that I didn't even want, need to just move on.
I would hope the rescue effort would bust the back glass or pry the trunk. If It was a life saving entrapment the whole side and top of that car and trailer would be opened like a can opener before dragging that car out.Pretty sure Matt was referring to the driver getting out of the car, or atleast that is where my mind went.
Dude that's hard to hear on multiple levels. Any idea why the first motor let go? Hate it for you man, but I'm sure you'll make quick work of it.No, just leaving it stock and unopened. I need to get the truck back on the road.
Hey I can't line bore if you keep shinny stuff. Congrats on the new equipment!
Thanks brother.Hey I can't line bore if you keep shinny stuff. Congrats on the new equipment!
“Taco-hootchie”
I thought it was touchmycoochie
I told you to take that Taylor Swift CD out of the radio.When you replace a thermostat and the radio spontaneously sets itself on fire
Good catch at least, could’ve torched the whole rigWhen you replace a thermostat and the radio spontaneously sets itself on fire
Where is this at?81 2 door v8 manual going through estate auction Saturday… I bet it goes cheap. Got it running for the family today. Super solid jeep.
Details on the auction? Always loved those 2 doors.81 2 door v8 manual going through estate auction Saturday… I bet it goes cheap. Got it running for the family today. Super solid jeep.
Exactly. I imagine the driver was fine since the energy transferred into the trailer and moved it 75yds or whatever, but you can't open the doors. And if you're that drunk, you probably can't find the trunk switch or figure out how to fold the back seat anyway.Pretty sure Matt was referring to the driver getting out of the car, or atleast that is where my mind went.
