np231 input shaft tech
strange1
Elkin
I have an 05-06ish nvg231 with a SYE already installed, but I need it to be 21-spline to throw it behind an AX5. I have a spare 21-spline case that should have the correct input shaft for the transmissions output, will it swap into the newer nvg231 case?
Or, should I be trying to swap the SYE and possibly the chain and/or planetary into the 21-spline case?
There are pre 94 and 95+ changes. You can swap any input from one of the same year range, but not cross that divide. Different helical angle started in 95.
Date code will be on the round tag
That’s cutting it close… the 21-spline donor is either a 94 or 95, I can’t remember. Lol
Best donor is a liberty, all the updates typically be bee saw more than stock tires and rarely 4wd, newer, the shift selector assembly from the recipient vehicle needs to be used in this case
