justjeepin86
- Jul 9, 2005
- Winston-Salem, NC
I need a dehum in my shop. I'm running ac now, but not keeping it cool enough to get rid of as much humidity as I want. What have you guys had good luck with? It's 600 sf.
I don't need it cool, but I need the humidity down. That's the only reason I'm running the ac. I thought i could keep it at 76 and keep the humidity down, but it's not that case. It's just a window unit, btw.A dehumidifier in the space is basically a little space heater. It'll remove the water in the air, but the heat it generates in the compressor, fan, etc, just gets rejected into the room. If you're looking to cool things off, that won't do. If you're just looking to remove water from the air, I'd still go with an AC unit.
A necessary evil even though they produce heat with a machine shop.I have two home owner grade ones in my shop. I have them set at 60% and on 24/7. My shop is 2400 square feet.
Figure out how to pipe a dehu into the shop so the coil doesn’t contribute negatively towards your AC?? I don’t know the math but I understand the problem.
Probably more importantly, is it leaky? Any little hole is letting water in.Is your shop insulated?
Yeah, not sure why he's against using ac. They are doing literally the same thing and using the same electricity, one just has the added benefit of cooling the space too. Just run the ac more.Then it's an AC unit. A dehumidifier is just an AC unit that has both the hot side and the cold side in the same space. Put the hot side outdoors, and now it's an AC.
This right here.Yeah, not sure why he's against using ac. They are doing literally the same thing and using the same electricity, one just has the added benefit of cooling the space too. Just run the ac more.
Yes, it's stick built and fully insulated. Minus the garage door.Is your shop insulated?
Well, it has a garage door. So sure, it is leaky there.Probably more importantly, is it leaky? Any little hole is letting water in.
What kind of AC are you currently running?Yes, it's stick built and fully insulated. Minus the garage door.
I get that, sortof. I thought there would be benefit to running both.
I have a 220 window unit that's permanently mounted thru the wall.What kind of AC are you currently running?
Assuming its a metal door, it’s worth insulating the garage door, even if it’s just to get rid of the cheap rattle-y sound when it opens and closes. But if you’re wanting to actually condition the space, having 70-80% of one wall uninsulated certainly isn’t helping. Also, if it’s a metal door, it will sweat due to the temperature difference from inside to outside. If it’s a wood door it’s not nearly as bad. If by chance it’s a roll up style door like at a storage unit, then you probably have to repla$e the whole door.
Exactly why I have regrets for going with the supplies package door on my building. Granted they are 14 by 14 and the eave is at 17 foot.What kind of AC are you currently running?
No benefit. Mechanically it's the exact same set of components. The only difference is that the dehumidifier has everything inside so the heat from the compressor is added to your interior space.I get that, sortof. I thought there would be benefit to running both.
It keeps it plenty cool, so i don't need another unit. I just didn't want to have to keep it so cool to keep the humidity down.No benefit. Mechanically it's the exact same set of components. The only difference is that the dehumidifier has everything inside so the heat from the compressor is added to your interior space.
I guess technically I just lied. Yes there is a benefit in that you WILL have additional moisture removal by adding the dehumidifier unit. But you also add heat which makes more work for the AC unit.
So if you just want it dryer and don't care that it is adding heat and is a pretty inefficient way to achieve the goal (e.g. you have both units already and are not really concerned about energy costs then yeah, run it
But if you're looking at buying a dehumidifier, just buy another window AC instead. Or a mini split
Both have a cool evaporator, which attracts moisture. Warm air hold more moisture than cold air so the dehumidifier is putting the heat back into the space so the air can grab more moisture to bring back for the evap to pull out. The window unit is targeting a temp, not a humidity level. It should still be dumping the water outside from the back somewhere. I would try your window unit on the lowest fan setting. That would give you the coldest evap temp and give the air moving across it the most contact time. What size is the unit? If its too big it will be pulling down the temp too fast and not giving it enough run time to strip out the moisture.It keeps it plenty cool, so i don't need another unit. I just didn't want to have to keep it so cool to keep the humidity down.
I still don't understand how the humidity is controlled the same. When the dehumidifier is physically dumping water outside thru a tube.
But, you and @Ron make sense. I'll pull the trigger on a mini when the time is right. For now, I'll just keep it cooler in there to reduce the humidity. If that's a thing. I hope to build on, so I don't want to add something new right now.
A dehumidifier works just like an AC but adds a recirculating section that passes the cooled air back over a set of heated coils to not col the air. IOW a dehumidifier is nothing more than a small inefficient ac unit. That discharges the hot air back into the space, where as your windows unit discharges the heated output air outside.It keeps it plenty cool, so i don't need another unit. I just didn't want to have to keep it so cool to keep the humidity down.
