Mower dies after running for 20-30 minutes
Bought a new fuel pump today. Installed it, cranked it without starting fluid finally. Thought I had it fixed. Ran like a champ for an hour. Stopped for supper. Went back out and cut for 45 more minutes without any issues. Then I’m a couple loops from done when I thought I heard it miss a little. Then again. I switch tanks and it stays running, other than a bit of stumbling as it switched over. But it then it really starts to stumble and I have to choke it to get back to the shop. Barely made it, but it didn’t quite die. Just hitting enough to stay running, but not enough to bring the deck on or go up a hill. If I took the choke off, i had to immediately pull it back on the keep it running. So it’s definitely fuel related, and changing the fuel pump made a big difference, but didn’t fully solve the problem.
not sure if this has been asked, did you go through the carb? maybe time for a rebuild or a new one?
I don't recall if it's been covered, or if another action you've taken can negate this, but have you checked inside your rubber fuel lines for a torn flap of rubber, or some sort of debris? Had a buddy chase a fuel delivery problem and it ended up being that one of the times that he crammed the rubber line back onto a hard line, the hard line cut a small flap of rubber that would act like a baffle and cut off fuel flow. pull the rubber line off and look in, and you wouldn't notice it. he just happened to inspect very closely and found it.
It's clearly a fuel delivery issue and it's erratic. It really sounds to me like there's some sort of debris, or something loose or something to that effect that is making it inconsistent.
Agree with this but if you go to the trouble of looking at them just replace.
Carb is 100% cleaned (and was clean as a whistle when I took it off), all fuel and vacuum lines are replaced also, with 300psi fuel injection style line. I replaced the pulse line with that line also, so that's the only other culprit, but I would think it would have caused an issue sooner than later instead of no issue after the first hour.
You may have said this before, but have you tried taking the fuel cap off when it starts running poorly?
Yes. And for good measure tried it when it was stumbling yesterday too. Yesterday was the first time it kept running long enough to trial and error a few things, such as switching tanks and bustin caps.
Have you pulled the valve covers and looked to see if the push rods are straight and moving correctly? What engine oil are you using?
I’m not sure if this is a joke or not…
I’ve set the valves, rods all looked fine, and it’s using whatever oil I put in it last year when I changed it.
No not a joke. You should only use Kawasaki oil. It's high zinc and is best for them. I've learned the hard way. Kawasaki is calling for 20W50. Too much friction in the valve train can make them miss and stumble and eventually cause damage. Yes, your situation sounds like fuel related but I've had the stumble and power loss and it turned out to be the push rods bent from not oiling properly.
Gotcha. I’m sure it was 20w50 but I honestly don’t remember what brand. I used a Kawi filter, and I think I got everything from the Ferris dealer, so there’s a chance it’s Kawi oil. If not, it’s probably Valvoline VR1 Motorcyle oil.
Well, I think I finally figured it out. Basically the only things I hadn’t replaced in the fuel system were the in tank pickup lines (inspected, looked good), the inline 1/4 turn fuel shutoff valve, and the fuel filter. Last weekend I decided I needed to eliminate the shutoff valve and filter from the list of variables, so I pulled off the hose assembly from the tanks to the fuel pump, and then decided to try to blow through it. Lo and behold, barely could get any air through. Filter was nice and clogged. When I checked the filter earlier in this saga, it was flowing fine, but in hindsight I should have replaced it while I was replacing the lines.
Anyway, I’ll give Mr ShreddusMcLettus credit where credit is due:
Fuel filter might be gunked even if it looks clean
Called it on page 1.
all the signs were pointing north, you went around the world but made it finally. (lol)
Same thing with a JD rider I had, however I could see that the fuel filter was nearly empty (one where the filter is in the line right beside the engine. Ended up being crap in the tank getting sucked into the pickup tube. Compressed air on the filter outlet blowing backward fixed it. I also learned that if you forget to take off the tank cap when doing that, you'll get a surprise when you let off the compressed air.
My typical solution
You didn’t change the fuel filter yet?
Sarcastic Charlie And The Chocolate Factory GIF
I want my money back on this movie.
I did check it early on in the process and it was flowing fine. I think it was a combination of a weak fuel pump and a clogging filter. Changing the fuel pump took the run time from 15min to 1hr.
After all this, you could have made up a much better story.
Like some asshole friend put a timer on the ignition, or the kids put a remote kill switch on it because you took away their motos because they called you Boomer.
Hey, I'm not too proud to share my failures. Hopefully it helps someone else. Nobody would have learned anything if I never posted or never posted a fix. Even if all you learned is that I'm a dumbass when I'm not a smartass, at least you got that. 🤷‍♂️
