Orbital valve
Last one i bought was off of Ebay. Been working well with no issues
Sorry to hijack this, but seems like a wealth of knowledge here…
I've got a full hydro PSC kit for Chevy 60 that is about to go in. I’d really like load reactive due to driving the pile around town. How do I find one with comparable flow so I don’t jack up the function of their setup?
I have one from ebay 250$ + shipping. Just the orbital, no neck or mount
I used it for one trip to Uwharrie for a shake down and went a reactive orbital. Which I could tell no difference between the 2.
Do you have the full kit, or just the ram? I would think their kits would be matched. I cannot find the tech info I had at one time, but best i can remember the steering valve needs to be roughly matched to your ram diameter, stroke ( ram volume), and how many turns you want from lock to lock. I would also reccomend one that will still work without pressure (engine off), don't remeber what that is called either. If your caster is setup properly, you should have return to center by default.
This is where I ordered mine from on my YJ. My buggy also had one from here as well (i believe it was already on the shelf and I forgot where it came from). Load reactive and non reactive available as well as options for flow.
Full kit from PSC. I definitely don’t want to jack with the flow they have built into the system that will work trying to get load reactive. X100 if I have the same outcome as @Jeff B
Are there any numbers or info on the PSC orbital? Or a link to the kit you got. Should be able to find out what size it is, and match that with a reactive one.
Headed to work on it now. I’ll snap a pic
I run a scotts custom offroad kit on the xj. the gear pump in his kit, he told me was about 4gpm and 1K rpm, @ the pump shaft. so at about idle.
I run a 2 x 8 PSC ram and with the 160mil orbital I am about 3.25 turns lock to lock. I relieve at 1800psi and there is a 1 Gal reservoir at my fuel tank in the rear.
working with the engine not running would require several check valves a 12V hyd system that would be pressure reactive with a couple pressure switches in line. Used to install these on motor graders. I may be able to fine you a basic schematic and harness is your going that rout.
