So, what had wrong in the wiring. I followed a couple of YouTube Univ. videos on how a couple of guys wired their 4.0 with HEI… apparently there’s a different or I just got it wrong.
I had ignition start wire coming out of firewall and spliced out to S terminal and run into 12V feed on the dizzy. Then I had the tach wire from the dizzy going to the I terminal.
Don’t ask me why, just understand that I’m mentally handicapped with wiring.
After trial and error and plugging and unplugging and thinking about it, it made sense to disconnect the I terminal. Made no sense as to having the tach to that.
It was giving power in the run position for the key.
After stepping away and disconnecting myself, I knew I needed a start signal from the key to the S, but with all the different wiring diagrams and color discrepancies I wasn’t sure which wire or how to trace it.
Then I found the TSM diagram and stared at it until I could understand it. Now I have single switched 12v to the dizzy, notch wire right now and a single wire to the S terminal. Being a solid green wire it matched the TSM diagram.
All good. Still don’t understand how I ended up wired the way I was. This makes sense. But to wire all of that and only have two out of place, I’m pretty impressed with myself.
