'84 Ford Crown Vic wagon, $400 POS spare car used primarily to drive 5 miles to and from work, purchased just after we moved to NC.
Blew brake caliper, decided that the rest of the front brake system needed to be replaced as well ( brake hoses were actually peeling) Calipers were $30ish a piece, cheap enough to do it all. Go to Napa, WITH the old calipers, don't wanna pay a core it a don't have too. one in stock, the other has to come from another store, they will deliver it too me at home. (frequent fliers get perks like this ).
INstalled calipers, made sure bleeder was up, yup sure did, pointing up and too the rear. I can't get pedal to save my life, bled 2 pints thru. I'm running out of time, I have to be at work, and then first thing next morning I have to drive 6.5 hrs to Ashville, can't be late (traffic court).
Took it to the shop down the road, they called me an hour later, it was done. $60
I had mounted the calipers on the wrong sides in my haste to get it done. yep, bleeder were pointing up, but they we NOT at the top of the caliper. Had I had not removed the calipers till needed, I wouldn't have done that. DUMBASS !
Blew the distributor cap off a fork lift a few months ago, cleaned off the area around dizzy with brake cleaner while doing other work, had cap off to gain clearance.
Reassembled, hit the key POP !! dizzy cap exploded, Whoops.
Got the full charge from an igniton coil a few weeks ago, pulled dizzy cap off while checking for rotor rotation, hit the key, still had cap in hand, coil wire connected. Lit my ass up good, nice ground path since my hand was on the metal key switch. That was "exciting"
Most fun wasn't actually a stupid, but something most would find very un-natural. I used to work on a lot of GM 6.2-6.5 diesels, would never fail, if you installed the intake before you checked for leaks from the injection pump, (injection pump hides under intkae) you would have a fuel leak. SO I got in the habit of starting the enigne without the intake in place. Also made timing the pump a shit load eaiser.
That is a very un-natural thing to see, but in reality, most diesels don't need the intake for anything other than air direction after a filter or intercooler.
Sounds pretty neat too.
DO NOT have any rags or other loose items any where close while doing this. they WILL be ingested, and it WILL cause damage.
