- Apr 18, 2005
- Greensboro, NC
Finally got around to messing with the TBI 350 SBC motor I got several months ago. Engine will fire up every time but will die out in a few seconds to a minute. New Affordable Fuel Injection harness and computer chip, IAC, TCS, O2, cap and rotor, fuel pump. Timing set properly (pretty sure). At key on check engine light flashes and then stays on until engine is started. Jumping pin A and pin B on the ADL connector makes code 12 flash continuously but no other codes present. Looking for any ideas from the TBI gurus. Any chance it could be the TPS? BTW, thanks to Yager for help with getting the distributor installed properly and timing!
Pulled the Affordable Fuel chip and went looking for my old chip. Found it damaged, pins broken, in a box
Thanks for all the ideas and tips.
