lifted toyota wont align?? ifs
LarrySmith89
New Member
Conway NC
my friend gave me a 3 1/2 inch lift for my 86 toyota, lifted my toyota and now the front is like this \ / and wont align. any way to fix this?
What kind of lift? Did you just crank the torsion bars to lift the front?
uncc-crawler says "cut the uh.......what's it called........in between the tie rods.........uh........the threaded rod?"
its a trailmaster 3.5 in lift
Did your lift kit drop the front diff and lower control arms?
Are you sure it's a Trailmaster 3.5 inch? If so, the tie rod ends do have to be cut to gain enough toe adjustment. If it's a camber problem, check the lower a-arm eccentric bolts, I have seen them mistakenly installed with the eccentric washer on one side flipped differently than the other, locking the camber adjustment. The full instructions for that kit are here http://www.trailmastersuspension.com/instructions/TP49_50.pdf if you want to re-check what you went through installing it if you didn't have them.
