I am sure most of the professional mechanics on here know about tamper resistant torx bits like this http://buy1.snapon.com/catalog/item...9&group_ID=285&store=snapon-store&dir=catalog
I went to pull my MAF sensor on the Duramax last night, pulled out my torx bit set and found out none of them worked becasue GM put tamper resistant torx bits on the MAF. It basically has a dimple in the bottom so a regular torx bit will not work. All I had to do was un-do my air box lid and loosen one clamp, then the top of my air box came off with the MAF sensor still attached. I shot it with a dozen or so shots of CRC MAF cleaner, let it dry and then put it back.
Sorry for the rant, it just pissed me off that I need a special torx bit and I had to undo 5 screws instead of two torx bits.
Hey Kevin I should have asked you first! any other special tools I should consider for the '03?
