VortecJeep
Powered by Uranium-235
- Aug 24, 2005
- Concord, NC
96 ZJ on 33s, stock drivetrain:
Bad metal on metal noise when coasting, it goes away when I press the gas and put it under load. Just started yesterday. This morning I pulled the rear diff cover and the side gears/spider gears are chewed up on the ends of the teeth. So far it doesn't look like the ring and pinion are damaged, but I can't rotate it to see it all because I left my jack at someone's house.
If it is just the side gears and spider gears, can those be replaced without going thru setting up gears? I don't want to put much money into this Dana 35.
