- Mar 20, 2005
- Morganton NC
When I bought the Hilton, I knew it had a leak in the master cylinder. no biggie, at least that's what I thought.
I bought a MC that looked like what I had. Very slight differences in it.The push rod is held in with a combination of a snap ring, and a washer. The washer was just a little small, so I made one out of a washer I had. Little thicker, but no biggie! ( WOW, how wrong could I be!)The bolt holes were just a little wider. No problem, I drilled out the mounting holes to the next size and it bolted up fine.
Bled out the brakes good pedal and all was good. The day I headed out for the Toy run in Mnt City, I got about a mile from home, and it would barely go. I could smell the brakes. I pulled off and could hear and smell them boiling inside the calipers. Calling friends, I figured out I didn't have them adjusted right, so I adjusted them. I also had to crack open the brake lines to release the pressure. All is good, it rolled as soon as I put into gear. Got on I 40, stopped at the fuel station and filled up. Off again, another mile, and locking up again. Bleed the lines, more adjustment, and off again. Several more times of this routine and I finally got to Mnt City. Same scenario on the way back home.
Well off to the shop to get them fixed, same thing to get it there.
Sooooo, long story short, I have had to replace everything in the brake system. First round of ordering the parts, got the right calipers, wrong rotors. So the search began for the right rotors. Found one supplier, they wanted $375 each! finally found another supplier through the internet and they were cheaper. $379 for two, shipped. So, on the the rear. I ruined the rear brakes too. They had to have everything, small parts, drums, the works. Drums were $180 each. All total so far I am into almost $1200 for the brakes, and that number will rise.
So, the problem??? The washer I made to retain the pushrod in the MC! The thickness of it doesn't allow the piston to come forward enough to release the brakes pressure! So that it what lacks as of now to make them work as they should.
Counting the rear output shaft I broke on the Jeep the trip cost me around $2000. Sooo, if telling this embarrassing story keeps one person from making the same mistake, all this typing will have been worth it.
house! Little chance the wooden construction will stay intact or stay connected to the frame...
