Ricky B
Wiiide Open
- Mar 20, 2005
- LKN - Tha Dirty Mo (Mooresville, NC)
Ok so this technically isn't a 4x4 so pretend I have swapped a 5.0 into a rig and am asking about it
My Dads DD is a 95 Mustang with the 5.0, we are having overheating issues and can't figure it out. Daily driving its fine but if you turn on the AC at all it will immediately overheat. Or if you drive on it hard it will overheat but I'm talking like high rpms for an extended amount of time.
We have replaced the thermostat and had the radiator flushed, there was no gunk in the system its clean, also replaced the radiator cap.
Now here's the part that has me worried - you can smell antifreeze all the time when its running, like no terrible bad but if you come to a stop light or something you can smell it. However there is no lack in performance in the engine whatsoever which you would assume if a headgasket was blown it would run bad.
This isnt a new problem, its been going on at least a year if not longer it just has been ignored since normal driving doesn't make it overheat and it hasn't been a primary DD vehicle till recently usually served backup for everyone kinda car.
I don't know if this is related but for some reason even thou its stock unless you run 93 octane in it it sparkknocks, but it has done that since we bought it like 7 years ago so thats nothing new.
However if it does heat up bad it will shut itself off and not let you start it again untill it cools off (computer failsafe maybe?)
Anyway anyone have any ideas? I guess my next step is to just replace the water pump and see if thats the issue it just is a pain on everyone cause its my Dad's DD right now and we don't have an extra car anymore since my lil bro is DDing my Z71.
