Where to buy new headlights?
BigClay
Knower of useless ZJ things
Winston-Salem
As some of you know some little punk smashed my ZJ's front headlights, so I finally got the insurance check and now it is time to go shopping. Sooooo, where is the best place to buy new headlights, turn signals, and marker lights?
I would suggest the WTB forum right here!
E-bay has headlights for $40
the cheap ebay ones suck, they leak, and the beam pattern is shitty. If you need something on there and are getting rid of the jeep, cheap is good. If you plan to keep and drive it, look elsewhere.
There is a place in morrisville, that sells aftermarket headlights and such, they are very inexpensive, but I can not recall the name right this second, maybe someone else hear has been there before.
For a headlight assembly, I would look for quality, b/c you really don't want to look back at it a year from now and the headlight is fogged up or has moisture in it.
The IPF H4 Lenses with the X51 Fatboy Bulbs from northridge4x4.com work great. Only around 130 bucks to your door and the brightest beam pattern on the planet and works with your stock wiring. Go check it out. They are a great company.
When I replaced the headlights in the WJ, 1aauto.com had the best prices I could find. You may try them.
