jeepman13
- Oct 15, 2008
- mills river
ok, is a 14-bolt or dana 60 rear axle too much for a cj 7 with a slightly modified 350 sbc (aftermarket intake/header, tbi), 700-r4, dana 300. i plan to run 36-37" max tire size and 4.56's or 4.88's. i will be running a dana 44 from a waggy in the front. usage will be medium+ offroad trails and street use. i am not extremely hard on the skinny pedal but i dont want to worring about breaking rear end parts whenever i go wheelin.
If these are overkill then i plan on running a 8.8 or dana 44. any good input/advice would be helpful. tnx.
Have you ever seen a 14 bolt? Imo it would be a lot harder to fit the 14 than the 9. The pinion is longer therefore shorter d-shaft. If you point the pinion on the 9 right at the output it will not be any lower than the 14. Just wandering.
With your setup and tyre size I would actually RECOMMEND the 14 bolt or upgraded D60 as the rearend of choice.
