Rox&Mud
CTB
- Nov 3, 2006
- Rocky Mount
I figured I see if any of you other 4.0 Jeep guys have ever had a problem like this. It seems that, rather suddenly, my ZJ became hard to start, meaning having to run the starter motor for much longer than the normal amount of time. It has always started eventually and occasionally will fire right up. When it starts after a long attempt it usually smells as if it had been flooded. Since this began, my fuel mileage has suffered by about 25% on average. The only known problem is the common 4.0 exhaust break at the collector, but I don't see how this could cause the other problem. I swapped in a new cap and rotor with no change. Checked plugs and they all looked good. Wires, plugs, cap, rotor and coil were changed about 10K miles ago.
Any insight would be helpful.
