marvilusone
- Oct 21, 2007
- Charleston, SC
Here's what I did on my Thanksgiving. Still have to get the sheet to plate the insides(it's just cardboard now) and make some protection for the radiator.
. I'm trying to get all the body, cage and interior work done while it's still low to the ground and mobile. Swing by and check it out sometime. I'm just having fun with the new Millermatic 175.
Go with a 9" rear...you don't want to risk your tire falling off if an axle breaks....and....9's are much more plentifulHP D44 front, 5.13's, spool
8.8 rear, 5.13's, spool
It's not really all that hard. The worst part is untaping everything. Once you do it you'll be suprised at how easy it is. The best way I've found to do it is cut all the plugs off that you don't need then untape everything and start following wires bact to the bulkhead. On my 95 the only fuse I have in the passenger compartment is the 7.5 amp one for the gauges. I put it in an inline fuse holder an did away with the factory fuse block. The fuse/relay block is still under the hood but alot has been eliminated on it as well. You would be suprised at how few wires it actually takes to run a 4.0L. I keep all the extra wire. I'll be running a seperate block for all my lights, CB, stereo and whatever else. I've done this a number of times on different year XJ's. I've often thought about going to the junkyard and pulling some harnesses and making standalone setups for those wanting to swap in a 4.0L. If anyone's interested in one PM me and we can talk.
The stock shackles don't give me enough length for the travel of my leafs. I tried the stockers on my old XJ and it killed the flex of the springs.why not just use stock shackles with the 4.5" leafs? they would be easy to stretch open to accept the wider front eye of the leafs too.
