HogeySpooner
Active Member
- May 12, 2008
- Greensboro, NC
I am leaking oil where my distributor mounts to the engine on my 4.2. I replaced the gasket twice, replaced the hold down and cleaned the hell out of both surfaces before I put it together. I don't see any bad spots on either mating surfaces. Here's what I've done to it recently; had the head off for a valve job and cleaning, replaced piston rings and rod bearings, replaced oil pump, replaced rocker arms, and everything you would do in between these major repairs. I took the distributor off to clean it and prime the oil pump. I can't get this thing to quit leaking to save my life. Anyone ever experience this before? Any suggestions?
