wrangler code
didnt really help mine is a 95 yj
Oh, in that case, I don't know about cycling the key, but you should be able to jumper 2 terminals the ALDL port to get the light to flash. There are plenty of sites that tell you the codes for OBDI.
To query and OBD-I-era computer for these codes, put the key in the ignition and turn the key to run (not start), then off, then run, then off, then run (that's 3 runs and 2 offs). Leave the key in the run position. The check engine light will turn on for a few seconds, then turn off, then (sometimes after 20-30 seconds) start flashing. The flashes are counting out 2-digit trouble codes. Fast flashes count up each digit, with a longer pause between digits. On TJ's with a digital odometer, the code numbers are printed on the odometer in addition to flashing the check engine light. 55 indicates the end of all codes. Once you've got your code list, consult the table below to see what they mean.
Then to check the codes
http://www.jedi.com/obiwan/jeep/dtc.html
