- Mar 17, 2005
- N. N. Raleigh, NC
First: I know its just numbers on paper, real world is where it's at etc.. (4link 4-link)
I've followed all the advice I've been collecting over the years as far as suspension designs and comments/input from here and pbb..
The summary of things to try to do:
- try to make your links parallel when viewed from the side
- make them as long as you reasonably can
- make them as flat as you reasonably can
- make the roll axis as high as you reasonably can
- vertical separation should be 6" or more. More especially for more horsepower and/or bigger tires.
- make the triangulated portion 40 degrees or more for decent lateral control.
With that. Here's what I've come up with. After hanging the motor in place to check fitment I came up with some real life measurements that I can hit with the link mounts
Note: Looking to do this on both ends with same setup..
I have lots of adjustment on the frame side upper.
Can hit 0%-150% AS
What say ye!
Can hit 0%-150% AS
What say ye!
