Ricky B
Wiiide Open
- Mar 20, 2005
- LKN - Tha Dirty Mo (Mooresville, NC)
Been trying to fix my Dad's old 66 f100 for ever now . . . can't seem to figure out what's happening.
has a 390, stock, 4bbl intake and holley 600cfm carb, carb fairly new, couple years old
anyway it keeps loosing fuel pressure, will run fine for a while then just randomly loose fuel pressure, then just randomly will come back again
replaced the pump and filters . . . no help
pulled all the lines apart, blew em out with air compressor no obstructions . . .
checked the fuel tank, no junk floating around that could possibly be clogging the pickup
said screw it , put a brand new electric pump, with regulator and fuel pressure gauge inline, set it to 6psi, let her roll . . . .
runs for a while, then randomly starts loosing fuel pressure, runs fine again, then there she goes again, you can hear the elec pump cavitating too . . . wtfreak is going on
any ideas . . . I'm pretty sure there is nothing between the tank and the carb that I haven't replaced or checked more than once at this point . . . whats going on?
Thanks
Thanks
what if its the wrong one. or got pluged up somehow ? this will create a vavume over time.
