- Mar 17, 2005
- N. N. Raleigh, NC
I've got a McCulloch FDD210 1800w Inverter Generator. I got it at NorthernTool as it was a good price IMHO. I wanted to start a thread that was search-able on the net for others who have similar generators and wanted some information about it. There seems to be little to NO information available they aren't even listed on the McCulloch site.
My unit is a FDD210 1800W unit.
Engine is stamped: 2J158FGH *0703060083
It has all the standard features, low oil shut down
1800W surge/1600 continuous.
65 dB (at standard 7 meters/21ft distance)
2.9hp 4 stroke / 105.6cc
13.3amp duplex outlet
12v 8amp outlet
1.45gal tank
run time ~5hr full load.
(I'm able to run my 5500w AC unit at ~1/2 load for 10+ hours.
I have my manual somewhere but other than describing maintenance stuff and showing the wiring diagram it really doesn't say much.
I've had to fit/tweak a few things on it so far but nothing I would consider abnormal for a low cost 'cheep' item. I wanted to post up what I knew for others to find.
Muffler: I ripped the exhaust muffler gasket when i removed the muffler. I was curious as to how the muffler was constructed and how difficult it would be to modify or extend it to reduce noise. I fabricated one from some .120 aluminum, been working fine. Conclusion other than maybe a water trap the muffler seemed really well built. Most of the noise is contained within the case itself. The exhaust is only a part of the overall noise. So maybe a box or vented enclosure if needed. I've found the unit to be very quiet for my needs. While not as quiet as a honda brand unit its actually pretty close ** ( see more info below. )
Carb Adjustment: The generator started surging at idle with the smart throttle (ST) on. It ran great with ST off ie high running speed. And it ran fun with ST ON at middle rpms. But when the load (my AC unit) would kick off the gen would surge, idles up and down floating until the AC turning back on loading it up again. I took the carb off to do some homework and here is what I found.
It is a Huayi brand carb. aka 'Honda Clone' carb on the net. this one is a P15E - P150-2-702250270 so based on that I was able to locate some information on some go cart sights that described how to tear it down and such. I tore it down and cleaned it out. There was no signs of debris inside so I out the bowl back on. There isn't much in the way of adjustment as the jet and emulsion tube more less are set for this particular engine/load and as long as its clean it should run.
(Warning: If you remove the motor on the throttle there is a small bounce spring on it that can shoot out)
Upon reassembly, the surging continued. So after more thought I concluded it was surging only at low/idle and the only way that condition happens is with smart throttle on and no load. I found a diagram that showed where the idle adjustment screw was. There was a small plastic cap on the screw that was easily removed reviling a small slotted adjustment screw. I did this with the carb. slid out but with a flex driver you could do it still assembled and bolted to the motor. It was at 2 turns out, so I turned it in 1/2 turn and restarted the generator. The idle smoothed out and now ran fine.
Best that I can find is that this motor is a honda 'clone' motor and most items on it are similar to honda motors. I've not had to do any parts swapping or interchanging but in researching this model on the net and rv sites it seems similar to the coveted Hondas and Yamaha brand units that are higher priced. (almost 2-3x) The only real advantage I see with those units is parts availability and reduced heckling at the KOA campground but RV snobs and Honda bigots. My hope is that by collecting information and comparing notes a list of interchangeable parts will be created to support these. This unit seems very similar to the new batch of inverter units that are out in the last few years being sold under many off-brand names.
A quick search shows the Generac brand looks very similar to this one. The outlet/controls look similar also. Kipor was once an off brand that now has gained acceptance on the RV sites and thus the price has gone up on them
funny how that works.
There are some really cheezy looking units out to that I'm not sure who make them, they seem to be more like HF (Harbor Freight) quality units but YMMV. It would be nice if the retailer/vendor posted info about who made the major components and parts availability.
12v 8amp outlet
1.45gal tank
funny how that works. There are some really cheezy looking units out to that I'm not sure who make them, they seem to be more like HF (Harbor Freight) quality units but YMMV. It would be nice if the retailer/vendor posted info about who made the major components and parts availability.
