lomodyj
- Mar 21, 2005
- Out in the Middle
Gonna start doing some checking on the CTD tomorrow. Wanted to get some ideas as for things to check. I'm pretty sure I poked a hole in the piston...but I want to check the "simple fixes" first before calling it dead.
The dealer pulled the codes, nothing came up. The oil looks pretty good and is not missing any.
Some of the symptoms. Sounds like it's "running on 5 cylinders", Smoke (white on start up) from tail pipe (was black when I shut it down in WV). Liquid seeping from all gaskets at the #5 cyl. (head to exhaust manifold, exhaust to turbo, turbo to exhaust brake), can't tell if it's fuel (deisel or grease) or oil. Hard start (cranks for a long time, and I usually have to give it a little fuel pedal).
I'll see if there is any air push from the oil fill cap or the lower burp tube when running.
I'll check the fuel filters.
I'll pull the valve cover on the #5 cyl.
Any other thoughts on what to check before I pull the motor out?
Truck info; 1996 Dodge CTD 12v 167K miles, ~2000 miles on grease conversion. Was hauling the YJ through WV and had the pyro up in the 900-950 range several times with down hill cools only getting it to the 700 range before we had to start going back up...Pyro is just after the Jakebrake at the down pipe.
A turkey fryer gone bad?????
(Still easier than a 'stroke tho)
