willness33
Here for the memes
- May 3, 2005
- Alexis,NC
Back story. I bought this house this time last year. The previous owner removed a siphon pump and installed a submersible sometime before I bought the house. The well is 190ft with 25gpm according to the plate on the casing. It was drilled in 1974. I have no issues running out of water. The problem is that the harder I run the well (washing cars, watering plants, multiple showers) the redder the water gets. I have an inline filter and have to change the cartridges about every 2-3 weeks. The filters clog that fast and cause the pump to short cycle. The filter is between the head and pressure tank. I will move it to the other side of the tank to fix the short cycle issue, but that's just a bandaid.
My plan is to pull the pump up about 10' or so depending on the static water level in the shaft. I will measure total dept and length of the pipe to make sure the pump isn't sitting on the bottom. Also, it seems that there may be no torque arrestor on the pump as everytime it cycles, the pipe sticking out of the head swings around wildly. I have a new torque arrestor to put on.
So, to any well people, do you think I can get clear water by raising the pump and proplerly installing the torque arrestor?
What is the acceptable level for ferric iron?
I've seen online testing places but they run in the $200 range for tests. They send you containers, you fill em up, mail them in and you get your results.
