Callalantee - Nov. 3,4,5
I'll probably see you there, what do you need me to bring for the clearing?
chainsaw is probably all. comanche got a winch??? probably need a snatch block . i dont have anything set in stone to clear but we'll find something
Will likely work on the blue trail exit for a while. Need to get some driving around done and map some of the rock gardens.
Nope, no winch and an open frt diff, you may have to toss me a strap a few times.
MH-
If you want to come by and borrow my recovery bag (snatch block, straps, shckles, etc) you are welcome to it. Just let me know.
TD
blue the exit for welder? i do have two gardens to show you that need to be mapped for sure.
no problem we prob wont go nowhere too crazy.
MH-
TD
wow todd now i remember why you are hero
I just got the free pass from the warden so, I will be there Saturday.
Black TJ on 33" Swampers and a tan hardtop. Please say hello to me.
What CB channel will everone be on?
Peter
anyone
does anyone know what the drive is like coming on 321. i am trying to figure out ow much time i should give my self.
2.5hrs at the most from your house, I've done it in just over 2hrs every time i've been though.
I live near the innersection of 321 and I40 and if i leave early (6-7am) it takes me 1 1/2 hr to get to Callentee.
Peter
#1 (head count)
I will be there around 9am.
Peter
im going to try and be there around 9 or so as well, ill be in a yellow cj5 with a phat paint job... where is a good place to meet people up? just trying to see where everyone will be at, im trying to get as much done as i can since im only going to be able to stick around till early afternoon
maybe if anyone sees this in time, would someone give me a call in the morning to make it easier on finding out where to go
see you guys out there
chris
919-612-6422
good times
well we hade a good time. all the toyotas did good, only one birf. my thuck did awesome. i did all of armorall. i think it was the first to do it with out winchin. i can't wait to go back. try some of the knew rock gardens.
what are you calling armorall? the rockgarden beside little tellico that runs parallel with it? if so thats been done numerous times by two guys i know of. we call it pull cable. where did armorall come from? did you make it to the other gardens we marked on the map?
armorall is up the creek bed between orange and silver, coming out of the creek bed at the base of "pull cable" rock garden.
Armorall is the creek bed just below Little Tellico and Pull Cable. It used to be the way to Little Tellico, till Orange got cut in. Armorall is one of the places that may get closed. Too much distruction of the creek bed, and it's causing some major silting down stream. It's gonna be watched next spring to see how bad the problems are, and then a decision will be made.
We didn't get much new mapped this weekend, but I'll be posting up a new map as soon as Alan has a chance to upload the parts we did see. We are guessing that what is already on the map is only about 2/3 of the trails available out there...I think that Callalantee could rival the size of Windrocks/Coal Creek. Not quite the difficulty level of Windrocks though. We did map out a couple of new rock gardens, difficulty levels of Pull Cable, one is much longer, but has no known exit at the top...We will need to set up some work weekends in the spring. Get some body's out there to add a trail from the top of Welder/Blue over to Black (near the top of Gray), fix the bottom of Blue (we got some of the trees cut, but not all), find a way from Blue over to the Green or Pink and to get an exit from the new rock garden towards Brown.
We have been told several times by the owners that this trail is shut down due to EPA & water contamination concerns. They even went so far as to drop trees and other bruch across various parts of the trail to keep people from using it. Of course- that has all been moved by wheelers. Never heqard of any study being done- only warnings that if you were caught in the creek you would be asked to leave!
