toyotafreak
they call me spaz
- Nov 14, 2006
- China Grove/Mooresville
While having a few beers and doing some heat transfer homework.. A buddy asked a question, figured its applicable to beer drinkin' so I'll share it...
Elliott:
What is the heat transfer from a beer can at 30 degrees Fahrenheit with an ambient temperature of 70? You can assume the effects of radiation are negligible.
Solution:
Assumptions: Steady-state;3-d convection; No heat gen; Laminar Air flow...blah blah....
The approx Heat Transfer: q=(Tc-Tair) }hdA * I used the symbol ,}, to denote integral across surface area)
Using Reynold/Nusselt/Prandtl for ambient air at 305K
So Heat Transfer: q=19500 (Btu/hr)
Applying an Energy Balance at an instant, i... (E_in = E_out)
... dT/dt]i = 0.008 (deg F/sec)
... so it is increasing temp at a rate of 0.006 to 0.008 degrees per second *(assuming its is full...in which now it is not, and I'm going to bed)
So what does this mean... drink more beeer
Elliott:
Solution:
I slept through Heat Transfer though, 8am was too early, and I despised differential equations anyway.
