Erik
- Oct 20, 2005
- Wilmington, NC
snapped some quick pics of the progress...
front axle is installed but nothing is put together on it... no knuckles, hubs, etc, which is why the tires are just sitting there and not quite in position right.
the tube fenders were from blue torch fab. i made inner fenders out of old washing machines i got for free. took two machines to get enough good metal. the whirlpool is much better made than the maytag, fyi.
the relays are for my electric fan, driving lights, and rock lights. they're all fused with a new fuse panel installed under the battery.
rear led's are BRIGHT AS HELL. definatly somewhat blinding. 62 LED lights i think.... got them off eBay
cb antenna mount is simple angle iron cut to size and drilled.
clevis mounts to be added to rear bumper still. rear bumper/crossmemeber replaced the oem crossmember and bumperettes. it's made of 2x4" steel tubing with 3/8" thick walls. it's the strongest bumper EVER! maybe not, but it's beefy.
still have not ordered my detroit or 5.38 gears, however the 35 spline yukon shafts are in there for the time being.
big rectangular PIAA in the picture is my reverse light.
fuel cell is a rci 2161 with a -8 to -6 AN reducer and a -6AN 90 degree barb summit racing fitting for the fuel supply. I ran 3.8" fuel injection hose from advance auto. the return is a -8 to -4AN receuver and 90 degree -4AN barb summit racing fitting. I ran 5/16" fuel injection hose for the return. The carter tbi fuel pump i'll be getting from summit will install on the crossmember where the fuel line makes two loops.... loops were my idea of a way to keep the pump primed but after rethinking it, they're useless and will not be part of the finished fuel system.
driveshafts need to be shortened still. need to make steering tie rod and drag link still.
