drkelly
Dipstick who put two vehicles on jack stands
- Mar 21, 2005
- Oak Ridge/Stokesdale, NC
What kind of RPM's will this engine sustain?
), '93 w/ A518, 3.54, 215R16s & "3K" governor spring (<$15 locally) would run 3300rpm+ @ 65mph+ (3rd/1:1) just fine, but it sure sounded like 4500rpm & brought a VERY uneasy feeling! The POS tranny would only pull OD on the flats/downhill before going nuclear
Kinda subjective, but...
In their stock config, a Bosch pumped 5.9L will run 24/7/365 loaded at max governed speed... about 2700-2800rpm. Their original application was ag/industrial implements (trash/irrigation pumps, generators, etc) and where the 5.9L "legend" was formed, well before Dodge ever dreamed of dropping them in their junk.
My old truck (then Snappy's, then?), '93 w/ A518, 3.54, 215R16s & "3K" governor spring (<$15 locally) would run 3300rpm+ @ 65mph+ (3rd/1:1) just fine, but it sure sounded like 4500rpm & brought a VERY uneasy feeling! The POS tranny would only pull OD on the flats/downhill before going nuclear
Another tranny option would be the Getrag... aside from Bruiser & the tuner crowd (300-400HP), their not very refined. but pretty dang tough.
The FSO-6406A is a overdrive 6spd. It will bolt directly to my motors bellhouse. You would never have to worry about tearing it up. Only downfall is having to do some tranny tunnel fab. There is a write up on pirate4x4 about a guy that kept tearing a 5600 out of his newer dodge and went this route. Google FSO-6406a it is a eaton tranny. Has alot of usefull info between all of them. Not much bigger than a nv4500 just bigger bellhouse.
The early model chevy 4500 with the really low 1st gear will not bolt up to dodge nv4500 bellhouse. From what my buddie told me.
ehhhh sort of.
The industrial history of the B is a bit mis stated here.
Sure it has ran Ag and G drive applications, but never at those RPMS...G-Drive (genrator engines) crank up unde 0% load wide ass open to 1800 rpms and never leave 1800rpm
but don;t plan a build aorund sustained 3000+rpms with the hopes of longevoty or fuel mileage.
best thing to do is find a complete intercooled truck and take all the parts from it then your not parts hunting to make it all work buying individual pieces adds up quick.
why not just buy a good used dodge, sell hauler and get a 16' trailer?
fair enough, sometimes I like to throw a wild card out there.
FWIW, I'd run 3.42's with either trans
with the hauler he has the jeep on the hauler and the camper behind.
With your proposal he pulls the campr or the jeep
Down sides to an NV4500 are:
Non granny gear reverse. I use 4low to back up a trailer.
BIG!!! gap in gear ratio between 3rd and 4th. Gotta wind 3rd out to 3000rpm and shift quick with a heavy load.
That is absolutely incorrect and rediculous. A 12 valve Cummins swap can be done cheap (reasonably) if you do your own work and get decent deals on parts.
