- Mar 24, 2005
- Stanley, NC
After spending the last 11 years making my jeep bigger, heavier, and more complicated, I came to a point where everything was pretty much how I wanted it. It rode great, drove great, flexed great, and never saw any offroad use.
The right opportunity came along, and I traded my built Dana 60's, Dana 300, and 38.5" Maxxis Creepy Crawlers for built Dana 30/35, NP231, and 36" SX's.
Specs of the jeep pre-trade:
00 TJ
~5300 pounds in daily driver trim
95"ish wheelbase
4.5" RE springs, 2" Bodylift, Teraflex longarms, OME Shocks
D60HP front, Detroit, 4.56, Sky Hi-steer, Hydro Assist, 1ton Steering
D60FF rear, ARB, 4.56, Shaved, Disc Conversion
38.5" Maxxis Creepy Crawlers on Procomp 8128's
4.6 Stroker
NV4500HD
Dana300, 4:1, Flipped, Twin Sticked, HD output
Stock Front Bumper with Warn 8274 and 150' of steel cable
Rear Swingout Bumper/Carrier
Heavy Fabbed Steel Rocker Protections
Short Term Plan
00 TJ
~4500 pounds in daily driver trim
95"ish wheelbase
2.5" OME Lift/Shocks, 2" Bodylift, Teraflex longarms
D30LP front, Yukon Zip Locker, 4.88, 30 Spline Chromoly Shafts, HD Steering
D35 rear, Yukon Zip Locker, 4.88, 30 Spline Chromoly Shafts, Custom Truss
36" TSL SX's on 16x8 Soft 8's
4.6 Stroker
NV4500HD
NP231 w/SYE
Stock Front Bumper with Warn 8274 and 100+ft of Synthetic Line
Spare tire mounted on rear door
Aluminum Rear bumper
Aluminum Rocker Protection
Stage 1 is to get the axles and t-case back in the jeep. Its hanging out on jackstands right now. The D35 I received in the trade had the upper CA's cut off and a claytons 4-link truss welded on. I am going to be running the stock jeep 5 link, so I swapped the internals into another D35 housing I had laying around.
Stage 2 will be to get the 2.5" springs under it, get or build the aluminum parts, and and do a DIY highline like I did to this red TJ:
www.nc4x4.com/forums/showthread.php?t=121651
Here's the sad day of years of hard work leaving (and lightweight parts and cash staying!):
00 TJ
95"ish wheelbase
4.6 Stroker
NV4500HD
Short Term Plan
00 TJ
95"ish wheelbase
4.6 Stroker
NV4500HD
NP231 w/SYE
:Rockon:
