UncleWillie
Rarely serious.
- Dec 29, 2010
- Vale
My well pump went out yesterday, so I get to spend today pulling it out and replacing it. 400 feet of pipe has to be pulled up to get to the pump. Anyone wanna provide slave labor for me.
What kind of pipe is it. How are you pulling it?
) and replace ALL skint wiring with the same type/AWG as original!*IF* there's not a chunk of "boat rope" directly attached to the pump (tied off at the casing)... add it before going back!
Adding to this... note he said "boat rope"... I can't remember the exact explanation, but a very reputable, and experienced, well driller told me several years ago to make sure the rope was poly. Don't use the white nylon rope you buy at Walmart. Seems like it was something about the nylon deteriorating in the cold wet environment. Maybe someone else can chime in on this. I've done several of those "well pulling" jobs in my time... hope I don't have to do any more. Good luck!![]()
Suuuuure I see you only posted AFTER i got it doneDamn, had I seen this sooner I would have gladly helped out.
No, I'm not just posting this because you're done.
Next time you need a hand with something, shoot me a pm. I work a lot in the spring and fall, but if I'm free I'll help out.
