pheery
- Mar 21, 2005
- High Point
bwahahahaha.
Rich said:It's however you wire it. I run my brake ground directly to the trailer frame, and there's a ~12 ga. ground wire going to the ground pin on the 7-way from the frame.
Never trust colors.. ONLY pin position. Pull the wiring out of the loom from the conenctor to the trailer, and start from ground zero. Or at the very least check for continuity between the brake pin on the connector and the other end of the wire... you can't have the end connected to anything when you do this test.
Are you sure your brake controller wiring from the dash to the back of the truck is good? have you hooked to a good trailer to test it, or tested it another way? What kind of brake controller do you have?
hahahahahahahahaha91yota said:HORRAY BEER!!!!
jrraw23 said:As far as what battery im runnin is an optima red top so that should be able to get it done
Rich said:What does your truck's battery have to do with the price of tea in China?![]()
Rich said:I won't even ask if you have a breakaway box on there, and what shape the battery is in.
Rob said:I'm going to say this because everyone is thinking it,
Your running a back yard fab shop and pulling stunts like this? And you can't wire your trailer brakes or use a meter?That's scary. Please let me know when your towing so I can get my family off the highway.
Metto said:dude he runs BEAST INC THE ULTIMATE MUD AND RETARD FAB SHOP
doc said:Hey Guys,
Everyone's got to start somewhere business-wise & lord knows he's payin' his dues w/ posts like these.
Doc
People you know and people you know's friend's parents will have no problems suing you when their precious little one gets hurt when something fails. They will also sue your parents since you live at home and they know you are doing work at their house. I assume they have deeper pockets than you...jrraw23 said:As far as the buisness thing its just work I do for people I know or people I know's friends mostly whenever I feel like it. Anything from a little 2" suspension lift to fabbin a suspension or bumpers etc. but yea it's nothin serious its just like for people i know whenever I have time cause I enjoy doing it and make a little money on the side.
Save your self some time and get a diagram form a trailer place or an RV dealer. They install these plugs every day and most will probly give you a copy of the diagram so you will know how its supposed to be wired. If I had a scanner I'd post one for you. If you find a real nice one they may even plug the tester in your truck to check your wiring. I wont say a word about your tow rig or trailer ( or your Buddy's )but at lest get some brakes on it.jrraw23 said:Yea there is alot of common sense little stuff that I don't know much about like wiring, etc. cause I just learn stuff as I go pretty much, so until I need to do something I don't know how to do it then I figure it out and know how from then on. After I get this trailer working I'll know how to wire a trailer up for instance.
