120v home shop/garage upfitting
It's just electrickery - if wired properly, no difference from you installing it than an electrician. Really not much to it, install a ganged breaker, wire both hots, and a ground, run to an outlet and connect there. Only gotchas would be wire size, breaker size, & proper outlet for it to be to code. (And should be more than 4ft from water if it's not a gfci circuit if my memory is correct, but I'm not an electrickery professional - I've got an adapter cord or two that "shouldn't exist" example- 220v parallel flat terminal plug to 120v plug for the plasma so I can use it within 26 ft of the outlet with a standard 120v drop cord. Should it exist? No. Does it? That's up to your imagination.)
Forgot to add that it doesn't matter what you do as long as it's doesnt catch fire burn your ________ down while you're not there, which is why everything gets turned off and unplugged when I go home. Even stuff properly wired should be turned off/unplugged when unattended in my book.
FWIW you can always make the long run in 240V, drop that power into a sub panel, then run all your branch circuits in 120V. And still have a provision for a welder outlet down the road since you’d have 240 there already. That way your longest run will be the highest voltage/ smallest wire.
Keep your neutrals and grounds on separate bus bars since the sub panel wouldn’t be the first point of disconnect (from line voltage)
So when I said I was an electrical dunce...I truly meant it. I'm capable of swapping light fixtures, outlets, switches...beyond that, when I plug in the item does it work, yes or no. It's just not a skillset I have, and think I understood about 7 words of what's quoted.
Dont feel bad, @336wheeler is kind of like our friendly neighborhood Rainman. :lol:
With the panel in the garage, my thinking is it's a no brainer. Run two 220v outlets. If there are not 4 spaces open in your breaker box, run power to a sub panel. Then run the outlets from there. If your garage is finished(sheetrock or something else) I would put the outlets near as you can from the breaker box. Harbor Freight has a really nice drop cord so you can move the welder around your garage. The compressor, if it's not gonna work to be clos enough to the outlet, just get either a drop cord or rewire in a longer cord. My best advice is to take the offer)s) of help!
Post a pic or two of said panel (one of the wall it's on & one with the door open)...
If the panel is of a surface-mount & has open slots - this is a very simple solution. Flush-mount panel complicates it a bit (aesthetics, mostly) - but not mo' room @ the inn makes it a little more difficult.
Many great ideas posted here...
Appreciate the advice and offers of help. Ended up talking to the electrician that sub-contracts for work. I wanted some more flood/spot lighting around the perimeter of my house and some interior/exterior lighting in my 12x24 shed. Told him I'd like to add some juice to the garage, said he'd do the garage for me instead of a fruit basket for Christmas. Not sure how often I'll use it at home, but it's better to have and not need, than need and not have, I suppose.
