1995 YJ SPRING OVER AXLE NEED ADVICE!
Discussion in 'Axles / Suspension / Tires' started by GMONEYSH22EG, Jul 5, 2011.
  1. GMONEYSH22EG
    GMONEYSH22EG New Member
    May 20, 2009
    WINTERVILLE, NC
    MY FATHER AND I ARE CURRENTLY BUILDING A YJ. IT CURRENTLY HAS A 6" SUSPENSION LIFT AND IT CAME WITH A 3" BODY LIFT. I AM NOT A FAN OF HOW BODY LIFT MAKES THE VEHICLE LOOKS. IT IS ON 35/14.50/15 PIT BULL ROCKERS ON A 15X12 WHEELS. I FEEL AS THOUGHT IT NEEDS A TOUCH MORE CLEARANCE ON THE REAR FENDERS SO I WANT TO DO A SOA SETUP LEAVING THE 6" SUSPENSION LIFT THAT IS CURRENTLY ON IT IN TACT. WHAT WOULD WE BE GETTING INTO AS FAR AS STEERING ISSUES AND DRIVE SHAFT ANGLES. THANKS IN ADVANCE FOR ANY HELP.
  2. GubNi
    GubNi 8 lug disc brakes?
    Mar 20, 2005
    Jonesborough, TN
    That seems like a crazy amount of lift for 35's. Spring over adds 8" I think.
  3. upnover
    upnover Grumpy, decrepit Old Man Moderator
    Mar 20, 2005
    Morganton NC
    I ran a 3 1/2" lift and spring over, and it cleared 44's
    A stock spring set up, and spring over, will clear 35's easy.
    If you are staying stock length, and want to do a spring over you will:
    Need to probably run CV type drive shafts, also longer
    defiantly need a traction bar for the rear.
    Longer brake lines
    Longer shocks
    degree shims to help with angles(geometry will change going from under to over
    I would highly recommend not using those springs with a spring over
    The amount of lift will be thickness from tube to top of perch plus thickness of spring pack
    Skid plate will probably need altered to accommodate the added angle of the drive shaft drop
  4. GMONEYSH22EG
    May 20, 2009
    WINTERVILLE, NC
    THANKS FOR THE ADVICE. I WAS READING THAT YOU WILL GET ABOUT 5-6 INCHES WITH A SPRING OVER. I AM MAINLY TRYING TO MAKE SURE THAT I HAVE PLENTY OF TRAVEL ROOM TO TAKE THE TRUCK TRAIL RIDING. I AM JUST NOT A FAN OF HOW THE BODY LIFT MAKES THE TRUCK LOOK.
  5. GMONEYSH22EG
    May 20, 2009
    WINTERVILLE, NC
    WHAT WOULD YOU SUGGEST TO GET JUST A LITTE BIT MORE OUT OF THE SUSPENSION LIFT KEEPING THE SPRINGS THAT ARE CURRENTLY ON THE JEEP.
  6. cj777
    cj777 Well-Known Member
    Mar 22, 2005
    Durham, NC
    If you want to keep the current springs and ditch the body lift, swap some TJ flares on and you should have more than enough clearance for 35s
  7. 95yjjeep
    95yjjeep Well-Known Member
    Jun 7, 2006
    Charlotte
    my jeep is SOA with a 2" bds lift spring and 1" body lift and i could lose a few inches and still clear my 37" iroks easily. that jeep will look tipsy if you keep a 6" lift and add 6 more inches from a SOA. good luck with the build. definitely run some tj flares. it'll open up the rear fender so much.
    snapshot for you.
  8. sos4x4
    sos4x4 Member
    Mar 3, 2011
    Monroe NC
    If you really want a little more lift and no body lift then make new leaf spring mounts to give you the additional lift. If you have a welder of course... Then make some shackles to match. food for thought..
  9. GMONEYSH22EG
    May 20, 2009
    WINTERVILLE, NC
    THANKS FOR ALL THE HELP
Share This Page
